Keyboard Shortcuts
Main Menu
Open
Ctrl + O
Export to iClone
Ctrl + E
Export OBJ
Ctrl + B
Export FBX
Ctrl + X
Export BVH
Ctrl + V
Reload
F5
Refresh
F6
Undo
Ctrl + Z
Redo
Ctrl + Y
Toggling to Object-Manipulating Tools
Select Object
Q
Move Object
W
Rotate Object
E
Scale Object
R
Preview Window and Camera Tools
Quick Camera Positioning
A - Left
S - Right
D - Back
F - Front
G - Top
H - Bottom
J - Face
K - All
Home - 45 Degrees
Camera Manipulation - Zoom
Z
Camera Manipulation - Pan
X
Camera Manipulation - Rotate
C
Information
Ctrl + F
Pixel Shader
Ctrl + F1
Tips - Speed movement:
Holding the Shift/Control key will increase/decrease the movement (of camera and object) speed by 10x.
Indicators (Show/Hide)
World Axis
Ctrl + A
Grid
Ctrl + G
Dummy
Ctrl + D
Play Bar
Play / Pause
Space Bar
Scrolling to Specific Sections in the Modify Panel
Node Section
I
Transform Section
T
Pivot Section
P
Normal Section
O
Animation Section
M
Character Section
N
Replace Mesh Section
V
Head Morph Section
B
Material Section
Y
UV Settings Section
U
