Blending Motion Clips
When applying motions one after the other, you will often come across a problem where the last frame of the first clip doesn't match the first frame of the second clip. The character may be in two completely different poses, and this can cause a problem when transitioning from one clip to another. In order to blend the poses, you need to use the Blending feature on the Timeline.
Each clip contains a transition area at the beginning. Find out how to use this area to blend two clips together below.
