Transition Curves in Tracks
In Cartoon Animator, you are able to set keys or add clips into different tracks. Interpolations can be customized between different curves so that the transition speeds between two adjacent keys, imitate the physical characteristics of how the object would move in the real world.
( Watch Tutorial - Basic Motion Clip Editing )
  1. In the target track of the Timeline, set two keys (take the Transform track as an example).
  2. Right-click on the Later one. Select the Transition Curve entry in the Menu.
  3. You will see the Transition Curve panel display on the screen.
  4. Move your cursor onto the transition profiles and the thumbnail will play an animated guide to show you the effect of the transition method.
  5. Click on the desired transition effect profile and close the panel.
  6. Drag the Strength slider to dramatizing or weaken the transition curve effect.
  7. The transition curve will then only be generated between these two keys.
Accelerate
Decelerate
Smooth
Pause and Move
Gain momentum before Move
Damping
Gain momentum and Damp
Stutter Start
End in a Bounce
Stuttering Start and End
Elastic Start and Sudden End
Sudden Start with Elastic End
Elastic Start and End
Step
Linear
