Project Settings (New for 2.1)
In the Project Settings panel you may adjust the length of the project, the time unit shown on the time counter, the viewing method of the camera and the background.
Click the Project Settings button to open the Project Settings panel.
Project Settings Button
Project Settings Panel
Time Setting Section
Camera Setting
The camera setting decides the viewing method of the camera.
Fixed Line Width
The setting within this group can determine the outlines of the objects in the scene to be still or ever-changing by scaling or zoom in/out.
Safe Area
The Safe Area determines the exportable area on the stage. It is shown in blue rectangle as shown below:
Background Setting
In this section, you may set the background of your project to a solid color or to a prepared image.
Video - External Files
By default, CrazyTalk Animator compacts all loaded video files into a project file, which increases the total size of the project.
To prevent this, you may click on the External Files button to have all the video files saved as external files. This can solve the over-sized project issue. However, do remember to move all the video files together, along with the project file if you move the project to another folder destination.
