Using the Attach Feature
After you
create composite props with
the prop composer, the components, also named sprites, are all at the same level
under the root node. However, you may need to group some sprites together to have them animate at the same time.
Use the Attach feature to group them.
Attach Feature
In the Stage Mode, select a compound prop created earlier.
Click the Prop Composer button.
By switching to the Scene Manager panel,
you will be able to see the sprites that are under the root node.
Select a sprite which is a child of another one.
Click the Attach button
and pick another sprite which you want as a parent.
The sprite will then be moved under the new parent.
If you transform the parent, then the child will be affected as well.
Note:
The Attach feature can only be done in the Composer Mode.
If you need to detach the sprite, then use the Attach feature and then pick the root sprite to detach from the new parent.
Please refer to the sections below for more information:
