Display Information Section
The settings in this section provide information for your reference during editing or recording. However, this information can not be seen in the output files.
Show Grid, Grid Color, Spacing and Size
Grid Off
Grid On
The default grid color.
The grid color changes to purple.
The grid spacing = 50
The grid spacing = 10
Grid size = 1
Grid size = 2
Snap to Grid
Check the Snap to Grid box so that your objects always snap to the intersecting points on the floor grid when they are manipulated by the Move tool.
Snap Grid = OFF
Snap Grid = ON
Angle Snap
You may check the Angle Snap box and define an angle that your objects will snap to when they are manipulated by the Rotate tool. They will rotate by the specified angle each time.
Angle Snap= 45
FPS
FPS (Frames Per Second) indicates the rendering performance of your system with the current project.
World Axis
When the World Axis box is on, a coordinate displays in the origin.
Stage/Composer on screen display
The Stage/Composer On-screen Display may show the mode name at the bottom of the working area to indicate if you are in the Stage or Composer mode.
Stage Mode
Composer Mode
Anti-alias
An anti-aliased output will produce a smooth image with less jagged edges and pixilated areas. Activate the box to turn the Anti-alias feature on.
Anti-alias Off
Anti-alias On
