Applying an Action Menu from the Library
The easiest way to embed an action menu to a character is through the Content Manager. You may apply, command and then re-apply another template to have the character
command various expressions, or motions, with a couple of mouse clicks.
Select a character in the Stage Mode.
Click the Action Menu button. You will only see
the Action Menu Editor, in the working area.
Go to the Action Menu content folder in the Animation tab of the Content Manager.
Double click, or drag and drop, a desired action menu template from the library.
You will see all the commands compacted in the template. Pick one command and the actor will start performing accordingly.
