Puppeteering - Body Parts
The Solo Body Part Puppeteering method helps you puppeteer specific body parts by mixing and creating a lot more motions than what the Base Motion category provides.
  1. Select a character.
  2. Go to a specific time frame where you want to start puppeteering the character's body movements.
  3. When the Body Puppet Editor panel displays, select Body Parts from the Body Animation Profile drop-down list.
  4. Select the Arm, Head, Torso or Leg icons.
  5. Pick a motion template from the body part category list.
  6. Press the Space Bar to start previewing. (Or click the Preview button and press the Space bar)
  7. The character will perform the built-in motion template when you move your mouse in a circle.
  8. Press the Space bar again to stop previewing.
  9. Press Ctrl + Enter to start recording, or click the Record button and press the Space bar to start recording the motion during puppeteering. The motion can be triggered with the same mouse motions as the preview mode.
  10. Press the Space bar or ESC key to stop recording.
    Note:
    • Click the Play button on the play bar to view the puppeteering recording results.
  11. Go to the time frame in Step 2. Repeat the steps to puppet and record by selecting individual body parts and motion presets.
  12. Once the recording stops, a clip containing all the recorded motions will be stored as a single clip in the Motion Track of the character.
