IP Port Setting
The Unreal Live Link plug-in is able to pass animations to the mapped contents in Unreal.
However, with the IP Port Setting feature, Unreal can be either installed on the local machine or any PC on the intranet, as long as you know the IP address and Port number of the machine.
IP Port Setting for Local
If iClone and Unreal are installed on your local machine, then the IP Address and Port will be:
- IP Address: 127.0.0.1
- Port Number: Customized (54321 by default)
IP Port Setting for PC on Intranet
If Unreal is installed on another PC on the intranet, then you can access it by entering the corresponding IP Address and Port number.
