Connecting to LIVE FACE (New for v1.01)
For faster and more stable data transferring, the computer and iPhones that participate in the connection sequence must be in the same domain. You could choose either of the following methods: shared Wi-Fi, Hotspot, or USB cable.
* It is highly recommended that you connect the iPhone X and the computer through a USB cable, in order to avoid a Wi-Fi connection quality problem and to ensure a smoother capture frame rate.
USB Connection
If your mobile data connection is enabled, then you can use the iPhone hotspot (3G/4G SIM card required) to share internet to the computer via USB tethering.
  1. Make sure that the latest version of iTunes is installed on the computer, which allows your iPhone to be recognized by the computer.
  2. Connect the USB cable to the computer.
  3. On your iPhone, go to Settings > Cellular > Personal Spot and turn it on. If your Wi-Fi is disabled, then select Bluetooth and USB only.
  4. Complete the settings on the computer and automatically get connected.
Wireless Connection
Once the connection between the iPhone X and computer is done, launch the LIVE FACE on the iPhone X to get the gear's IP address for completing the Facial Expression Capture workflow on the iClone client. In this case, using USB connection that comes with the default IP address 172.20.10.1 as shown.
When LIVE FACE is successfully connected to the client, a blue success message will appear on the top and a client logo will shown on the bottom as well.
