The Window menu on the main menu bar contains commands for you to
switch between different preset layouts and show/hide various toolbars and panels.
Workspace |
This item contains a sub-menu for applying preset layouts according to your working conditions.
Toolbar |
This item contains a sub-menu for you to show/hide the
Project,
General,
Camera and
Physics toolbars. |
Modify (F6) |
This command opens the Modify panel for adjusting parameters belong to each object in the scene. |
Visual Settings (F7) |
This command opens the Visual Settings panel for modifying the settings of lights, shadows, Toon Shader and visual effects. |
Content Manager (F4) |
This command opens the Content Manager panel for applying embedded and custom templates to your scene. |
Scene Manager (F5) |
This command opens the Scene Manager panel to view all the objects included in the current project. |
Mini Viewport (F8) |
This command opens the Mini Viewport panel to display another mini preview window on the main preview window. |
Timeline (F3) |
This command opens the Timeline panel to edit animation keys and clips for actors, props, cameras, lights, sounds, effects, etc. |
