The Collect Clip track is a very unique track. You cannot set keys in it, nor can you add any clips to it. However, it allows you to collect keys and clips, merge them together to generate a whole new perform clip.
All the clips and keys in the tracks listed above will be merged and compacted into a motion file. You may then import it back by right-clicking on the Motion track and selecting the Import command.
If you wish to generate custom motions for both hands, then you may select the
Add Gesture to Library item when
you right-click on the Collect Clip track.
The motions collected will be saved in the Custom library.
Note: |
You can select the Add Motion to 3DXchange or Add MotionPlus to 3DXchange to directly
send the collected motion clips to the motion library for further use.
For more information, please click the links:
What is MotionPlus
and
Animation Section page of the 3DXchange Online Manual. |
All the clips and keys in the tracks listed above will be merged and compacted into an animation file. You may then import it back by right-clicking on the iProp and selecting from the Perform menu section.
This is a very practical feature for you to create your own animated props, or so-called, Helper. You may attach other static objects to the helper and then generate the animation for the objects along with the helper. For more information about the helper, please read Creating Animation Helper and Prop Animation with Helper sections.
All the keys in the transform tracks will be merged and compacted into this prop. You may then right-click on the prop and apply the animation in the Perform menu section.
