File Operation
Function |
Hotkey |
Notes |
New Project
Ctrl + N
Create new project.
Open Project
Ctrl + O
Open existing project.
Save Project
Ctrl + S
Save current project.
Save Project As
Ctrl + Shift + S
Save current project as another file.
Import
Ctrl + I
Import files in supported formats.
On-screen Display
Function |
Hotkey |
Notes |
Show online help
F1
Show Online Help.
Show/Hide Timeline
F3
Show/hide Timeline panel.
Show/Hide Content Manager
F4
Show/hide Content Manager
Show/Hide Scene Manager
F5
Show/hide Scene Manager
Show/Hide Modify Panel
F6
Show/hide Modify Panel
Show/Hide Visual Settings Panel
F7
Show/hide Visual Settings panel.
Show/Hide Mini Viewport Panel
F8
Toggle Mini Viewport On/off.
Show/Hide Play Bar
F9
Show/Hide Play Bar panel.
Show/Hide Preference Panel
Ctrl + P
Show/hide Preference panel.
Show/Hide Project Settings Panel
Ctrl + Shift + P
Show/hide Project Settings panel.
Show/Hide Edit Motion Layer Panel
N
Show/hide Edit Motion Layer panel for the selected actor, prop or accessory.
Show/Hide Gizmo
Ctrl + Q
Toggle Transform Gizmo Mode On/Off.
Show/Hide Grid
Ctrl + G
Toggle 3D Floor Grid On/Off.
Show/Hide FPS
Ctrl + F
Toggle Frame Rate (FPS) display On/Off.
Show/Hide World Axis
Ctrl + A
Toggle World Axis On/Off.
Show/Hide Dummy Object
Ctrl + D
Show/hide Dummy props.
Show Pop-up Menu
Right Mouse Button
Show the Pop-up Menu.
Switch Render State
Ctrl + R
Switch between Wireframe/Normal render states of the selected object.
Layout Preset
Layout |
Hotkey |
Notes |
Standard
Ctrl + 2
Animation
Ctrl + 3
Visual Effects
Ctrl + 4
Final Render
Ctrl + 5
All Panels
Ctrl + 6
Working Area
Function |
Hotkey |
Notes |
Undo
Ctrl + Z
Undo
Redo
Ctrl + Y
Redo
Play/Pause
Space bar
Left Arrow Key
Go to previous frame. |
Right Arrow Key
Go to next frame. |
Stop
Press down "," key to stop playing and go back to the first time frame.
Current Frame Preview
F10
Press the button to preview the render result.
Toggle Angle Snap On/Off
Ctrl + E
Toggle Snap to Grid On/Off
Ctrl + W
Toggle Snap to Model On/Off
Ctrl + M
Copy
Ctrl + Move/Rotate/Scale
Copy the Selected Object.
Delete Object
Delete
Selection
Ctrl + Left Mouse Button
Multi-Selection.
Toggle to Select Tool
Q
Toggle to Move Tool
W
Toggle to Rotate Tool
E
Toggle to Scale Tool
R
Move Tool (Gizmo hidden)
Left Mouse Button
Roll Mouse Wheel
Right Mouse Button
Both Mouse Buttons
Move along X-Y Plane.
Move along Z Axis.
Rotate by Z Axis.
Scale uniformly.
Rotate Tool (Gizmo hidden)
Left Mouse Button
Right Mouse Button
Both Mouse Buttons
Rotate by Z Axis.
Rotate by Y Axis.
Rotate by X Axis.
Scale Tool (Gizmo hidden)
Left Mouse Button
Right Mouse Button
Both Mouse Buttons
Scale uniformly.
Scale along Z Axis.
Scale along X-Y Axis.
Align To
Ctrl + L
Pick Material
B
Generating Textured Object
Dragging Texture to Space with Right Mouse Button
iClone pops up a menu for you to determine the objects
you can generate through this method.
Assign Textures to Desired Material Channels
Dragging Textures to Objects (containing Eight Material Channels)
with Right Mouse
Button
iClone pops up a menu for you to determine to
generate specific objects or the
target channel of the object for loading the texture image.
Create Objects
Click on Space with Right Mouse
Button
generate lights, path, camera, or to remove the animations in the
entire project.
Working Area - Camera and Light Manipulation
Function |
Hotkey |
Notes |
Roll X-Z
Right Mouse Button
Press down and drag in the 3D viewer to roll the view on X-Z plane.
Zoom In/Out
Mouse wheel
Scroll the mouse wheel to zoom in/out the 3D viewer.
Speed Zoom In/Out
Right + Left Mouse Buttons
Press down both the right and left mouse buttons to speed up zooming of the 3D view.
Quick Camera Positioning
A - Left
S - Right
D - Back
F - Front
G - Top
J - Face
K - All
Home - 45 Degrees
Press F to view the selected
object (character,
accessory, prop) face front.
Press Home to snap the camera
to a 45 degree perspective of the selected object (character,
accessory, prop).
Camera Manipulation Switch
Z - Zoom
X - Pan
C - Rotate X - Y
V - Rotate X - Z
Tips - Speed movement:
Holding the Shift key while zooming, panning, rolling and rotating will increase the movement speed by 10x.
Manipulate Camera in Object Editing Mode
Alt + Left mouse Button
Alt + Right Mouse Button
Alt + Both Mouse Buttons
Move Camera.
Rotate Camera.
Zoom Camera.
Combo camera switch
H
Switch between Preview and previous Cameras.
Camera & Object switch
U
Switch between current Camera and previous object.
Light & Object switch
Hold this key to rotate the last selected spotlight or directional light. If you
have never selected any light, then the first light listed in the Scene Manager
will be the target one for rotating.
Item Transform
Function |
Hotkey |
Notes |
Move along X Axis
Alt + Right/Left Arrow Keys
Move along Y Axis
Alt + Up/Down Arrow Keys
Move along Z Axis
Ctrl + Up/Down Arrow Keys
Rotate by Z Axis
Ctrl + Left/Right Arrow Keys
Accelerate Movement
Combining Above Keys With Shift Key
