There are some notices you need to know when you wish to export Panorama Videos.
When the Exporting Panorama feature is turned on, the camera view will be automatically changed to square view in order to be correctly stitched.
The original camera resolution before the Exporting Panorama feature is turned on |
The resolution is automatically changed to square after the Exporting Panorama feature is turned on |
Each of the cameras in the project will be set to Wide-Angle (12 mm focal length) when the Exporting Panorama feature is turned on.
The original camera lens before the Exporting Panorama feature is turned on |
The camera lens is automatically changed to 12mm after the Exporting Panorama feature is turned on |
Note: |
The value of the camera lens for Panorama Videos is
strict. Therefore, you are not allowed to customize this value
when the Exporting Panorama feature is turned on. |
There are also some limitations when you wish to export a Panorama Video:
The original project covered with an image layer |
The image layer is shown 6 times after the Panorama Video is exported |
The original project with a background image |
The background image shows repetitively after the Panorama Video is exported |
The original project with HDR - Tone Map turned on |
The seams between each camera views are apparent |
