You may use DAZ as a character motion creator (FBX or BVH) for
iClone characters. With the steps below, the exported motions can be smoothly converted
via 3DXChange.
Baking the Motion to the Character
Create a custom character (Note that default Genesis
characters are preferred).
Select the Window >> Workspace >> Select Layout command.
Make sure you choose the proper layout from the Layout drop-down list.
Show the animation timeline:
If you are using the Full Service [Beta] layout, then switch to the Pose & Animation tab.
If you are using the Hollywood Blvd layout, then switch to the Pose & Animation tab and
click on the aniMate2 tab.
If you are using the Self Serve layout, then switch to the Posing | Shaping mode and
If you are using the City Limits layout, then click on the aniMate2 tab.
Apply poses or motion clips to the character.
Right-click on the blank space, activate the Studio Keys and select the Bake To Studio Keyframes command.
The pose and motions will be converted into motion keys.
