Supported file formats for BuildingGen
The BuildingGen plugin utilizes specific assets and files for building creation and only supports modifications for buildings with the correct file format. Understand these file formats to avoid using incompatible assets when working with BuildingGen.
- iProp: iProp is an object that is specifically designed for the iClone environment, and any assets imported into iClone will be automatically converted into iProps.
Note:Optimized buildings will be converted into iProps, which can no longer be modified using the BuildingGen plugin. - iBuilding: Buildings generated by the BuildingGen plugin can be saved as iBuilding files. These files are supported for modification by the BuildingGen plugin as they have not been flattened with the Optimized feature.
- iBuildingConfig: The building file stores information on the unit parts and materials that will be used for building generation through selected building styles and their default configuration settings. When executing the file in iClone, the New Building panel will appear and will utilize the corresponding iBuildingConfig file.
