Teeth and Tongue (New for v1.24)
Teeth color and brightness can vary based on age, race, gender, and ethnicity. Whether you want your character to have a radiant smile with neat and glistening teeth, or ferocious creature to have intimidating and gritty teeth, anything is achievable with the help of the Teeth and Tongue shader. Ambient Occlusion properties are also provided to control shading inside the mouth cavity. Combine these parameters with the use of Character Creator morph sliders to generate variations with the best results.
Playback the video to learn the main concept.
  1. Teeth Shader > Normal Strength – It’s advised to tone down the normal strength if it’s too heavy.
  2. Teeth Shader > Teeth Desaturation and Teeth Diffuse Brightness – Adjust the saturation and brightness of teeth.
  3. Teeth Shader > Teeth Front Roughness and Teeth Front Specular – Adjust the reflectiveness and glossiness of teeth.
  4. Teeth Shader > Teeth scatter: Increase the subsurface scattering (SSS) of the teeth.
