Digital Human Teeth
Upper/Lower Teeth: The teeth model consists of two separate parts, the upper jaw and the lower jaw.
- Common
- SSS Color: Select the color you want for your teeth and gum when light passes through it.
Default color for the teeth.
The color blue was selected for the upper jaw.
- Edge Color: Select the color you want for the edge of your teeth.
Red is added to the edges of the teeth on the upper jaw.
- SSS Strength: Adjust the SSS reflection effect to add moisture and enhance the transparency of the teeth and gums.
SSS Strength = 0.000
SSS Strength = 3.000
- Normal Strength: Adjust the strength of the normal map to change the visibility of surface details like bumps, and grooves.
Normal Strength = 0.000
Normal Strength = 2.000
- Front / Rear Roughness: Change the roughness map intensity to control how much light interacts with the teeth and gums surfaces.
Front / Rear Roughness = 0.000
Front / Rear Roughness = 1.000
- Front / Rear Specular: Adjust the value to control the intensity of highlights on the teeth and gums. A higher value will increase the number of highlights in these areas.
Front / Rear Specular = 0.000
Front / Rear Specular = 1.000
- Teeth
- Teeth Micro Normal Tiling:
Teeth Micro Normal Tiling =0.000
Teeth Micro Normal Tiling =20.000
- Teeth Micro Normal Strength:
Teeth Micro Normal Strength = 0.000
Teeth Micro Normal Strength = 2.000
- Teeth Brightness:
Teeth Brightness = 0.000
Teeth Brightness = 5.000
- Teeth Desaturation:
Teeth Desaturation = -0.400
Teeth Desaturation = 0.600
- Gums
- Gums Micro Normal Tiling:
Gums Micro Normal Tiling = 0.000
Gums Micro Normal Tiling = 20.000
- Gums Micro Normal Strength:
Gums Micro Normal Strength = 0.000
Gums Micro Normal Strength = 5.000
- Gums Brightness:
Gums Brightness = 0.500
Gums Brightness = 1.500
- Gums Desaturation:
Gums Desaturation = -0.320
Gums Desaturation = 0.280
