Digital Human Tongue
- Type: Display the type of model currently selected. If “None” is displayed, it means the selected model is not supported by the plugin.
- SSS Color: Select the color you want for your tongue to show when light passes through it.
SSS Color = White
SSS Color = Black
- SSS Strength: Adjust the SSS reflection effect to add moisture and enhance the transparency of the character’s tongue.
SSS Strength = 1.500 (default)
SSS Strength = 0.000
- Normal Strength: Adjust the strength of the normal map to change the visibility of surface details like bumps, grooves, and scratches.
Normal Strength = 1.000
Normal Strength = 0.100
- Micro Normal Tiling: This value determines the tiling times of the Normal Map on the entire tongue mesh.
Micro Normal Tiling = 17.143 (default)
Micro Normal Tiling = 0.050
- Micro Normal Strength: Adjust to either intensify or soften the micro normal map of the tongue mesh.
- Brightness:
Brightness = 1.000
Brightness = 0.500
- Desaturation:
Desaturation = 0.020
Desaturation = 0.250
- Front Roughness:
Front Roughness = 0.000
Front Roughness = 1.000
- Front Specular:
Front Specular = 0.000
Front Specular = 0.700
- Rear Roughness:
Rear Roughness = 0.000
Rear Roughness = 1.000
- Rear Specular:
Rear Specular = 0.000
Rear Specular = 1.000
