Setting Actor's Idle Motions
To make a CrazyTalk actor look alive, setting idle motions to it is one of the best things you can do. The idle motions animate the actor when there are no events or any other interactions, and the game is in waiting mode. You may use the API command to define the idle motions of the actor so that it auto-moves in accordance with various scenarios.
Using the Example
The API Command
