Managing Multiple Projects in Bitmap Editor
When you have created a number of objects in Cartoon Animator from multiple PSD projects in an image editor, you can utilize the Bitmap Sync tool in the Scene Manager to locate an object project in the Bitmap Editor at ease and synchronize its editing to the existing objects in Cartoon Animator.
Follow the steps below to manage your projects in a Bitmap Editor.
Let's assume that you have continuously created several PSD projects in the image editor,
and have converted these projects into a scene, prop or character in Cartoon Animator.
Open the Scene Manager (F5) and
you'll find that the corresponding objects are marked with a Bitmap Sync
icon,
which indicates that an object is currently synced with its PSD project in the image editor.
You can go to the image editor and keep on editing these synced PSD projects at any time. When you are satisfied with the current result, update the images back to the object in Cartoon Animator (Ctrl + S).
You can also launch any object in the working area (the Cloud in the scene for example) to the Bitmap Editor.
The Bitmap Editor will be invoked automatically, and the selected object will show in a new project file tab (called "Cloud" in this case).
Back in Cartoon Animator,
you can see the Bitmap Sync
icon appears for the launched object.
Repeat Steps 3 and 4 to launch the other objects.
There will be just as many new project file tabs opened in the Bitmap Editor for you to edit and update to Cartoon Animator.
Now you can see that all the launched objects are marked with the
icon in the Scene Manager.
If you want to quickly locate an object's project file tab in the Bitmap Editor,
click on the
icon of the object like what was done for the "Mountain" layer below.
Note:The synced PSD editing may lose connection under the following conditions:
- The object has been edited in the Composer mode.
The object has been updated by another project file which is also currently synced with Cartoon Animator.
For example, the subsequently launched scene object will be affected by the initial scene project.
The Bitmap Editor will be invoked and with the corresponding project file tab automatically selected.
Note:While synced, Bitmap Editors (either Photoshop, or Clip Studio Paint) will switch to the project file tab automatically once you click the
icon.
- If you accidentally close a project file tab in the Bitmap Editor, you can return to Cartoon Animator and launch the Bitmap Editor for the object again.
You can also keep the original PSD source files for further usage.
Select the object in the Scene Manager and click the Find PSD File command in the Menu list to locate its PSD project file.
Note:The PSD project files you create are saved in a temporary folder during operation. You can define where the temporary files are saved in the Scene Undo section of the Preference panel (Ctrl + P).
If you remove the PSD files under the temporary folder, the program will fail to update the launched objects.
