Color Codes in Layer Manager
There are three color types for the items in the Layer Manager.
  1. Light Grey: The mouse cursor is hovered over the item. It informs you that the item is ready to be selected.
  2. Dark Grey: The item is selected. You can hold the Ctrl key to multi-select different items.
  3. Pink: The items that are connected as an entity formed by the Attach feature will be highlighted in this color. It can be props or accessories.
    • If you drag the item in pink with your LEFT MOUSE BUTTON, then the item will be individually moved to another layer level in the order list.
    • If you drag the item in pink with your RIGHT MOUSE BUTTON, then the items connected to it will also be selected and moved along to another layer level in the order list.
