Using Accessories
In CrazyTalk Animator Version 3.2 or above, character's accessories are provided and embedded. You can find the templates in the folder by default:
- C:\Users\Public\Documents\Reallusion\Reallusion Templates\Cartoon Animator\Accessory\
To use the accessories, you can follow the methods below:
- In Stage Mode: Simply drag and drop the accessory onto the character to whom you want the accessory to be put on.
Or you can select the character and double-click on the accessory template to apply it onto the character.
- In the Composer Mode, you can also apply an accessory with the same method from the Content Manager.
You can also drag and drop a Prop to a target bone to convert it into an accessory. Please refer to the Converting Props to Accessories section for more information.
