Time Warp for Motion Clips
By default, the playback speed of character motions and prop animation clips are linear. However, you are allowed to alter the clip with dynamic speeds, which means that the speed of the motion or animation can be altered within the clip.
  1. Apply a motion clip to a character. By default, the motion will be set to Linear mode.
  2. Open the Timeline (Shortcut Key: F3) to show a character's Motion track.
  3. Right-click on the motion clip and select the Time Warp entry in the Menu
  4. You will see the Transition Curve panel displaying on the screen.
  5. Move your cursor onto the transition profiles and the thumbnail will play an animated guide to show you the effect of the Transition method.
  6. Click on the desired transition effect profile and close the panel.
  7. Drag the Strength slider to dramatizing or weaken the transition curve effect.
  8. Play back to view results.
    Accelerate
    Decelerate
    Smooth
    Pause and Move
    Gain Momentum before Move
    Damping
    Gain Momentum and Damp
    Stutter Start
    End in a Bounce
    Stuttering Start and End
    Elastic Start and Sudden End
    Sudden Start with Elastic End
    Elastic Start and End
    Step
