Exporting Ratio for Prop PSD Launch
When you use the PSD launch feature in the Stage or Composer mode, you will first encounter a dialog asking you to enter the target size for exporting the prop.
- The default value 1.0 for the PSD Scale slider means it will export 100% size of the current prop.
- Please note that the exporting size does not actually change the prop's width and height in Cartoon Animator. It only changes the resolution of the images.
Note:
For the PSD Launch in Stage mode, the image structure of the prop is the same with the PSD Launch in Composer mode, however, the layers of their pivots will be set to invisible.
Pivots are hidden in the Stage-launched image. | Pivots are shown in the Composer-launched image. |
