Changing the Layer Order of Sprites
After creating a prop with multiple sprites, you may adjust the sprite layer order in a compound prop with the Composer. You may arrange the visual logic of the prop as seen below.
Before adjustment |
After adjustment |
Select a compound prop. Click the
Composer button to enter the Composer Mode.
Switch to the Scene Manager.
Select the item for which you want to change the order.
- Click the Move to top, Move up, Move down, and Move to bottom buttons to re-arrange the order of the selected item.
You will be able to instantly see the changes inside the working area.
Repeat the steps until the look of the prop meets your visual logic.
