Shortcuts in Modes
3D Motion Key Editor |
Function |
Shortcut (Windows) |
Shortcut (Mac) |
G2 and G2+ Actor Angle Key |
] (45 degrees rightward) |
[ (45 degrees leftward) |
Move |
W |
W |
Rotate |
E |
E |
Runtime Composer |
Function |
Shortcut (Mac) |
Show/Hide Bone |
B |
B |
Layer Editor |
Function |
Shortcut (Mac) |
Multiple Select/Deselect Sprites |
Ctrl + Shift + Select Sprite |
Command + Shift + Select Sprite |
Ctrl + Select Sprite |
Command + Select Sprite |
Puppet Editor |
Function |
Shortcut (Mac) |
Preview Start/Stop |
Spacebar |
Spacebar |
Record Start |
Ctrl + Enter |
Command + Enter |
Working Area |
Function |
Shortcut (Mac) |
Undo |
Ctrl + Z |
Command + Z |
Redo |
Ctrl + Y |
Command + Shift + Z |
Show Validate Multi-Angle Setup |
Select Sprite + M |
Select Sprite + M |
Show Actor Proportion |
P |
P |
Show Render Style |
R |
R |
Show Sprite Editor |
Select Sprite + S |
Select Sprite + S |
Show/Hide Bone |
B |
B |
Mirror Selected Sprite |
Ctrl + Shift + M |
Command + Shift + M |
Mirror to Actor Left |
Ctrl + Left Arrow Key |
Command + Left Arrow Key |
Mirror to Actor Right |
Ctrl + Right Arrow Key |
Command + Right Arrow Key |
Actor Proportion |
Function |
Shortcut (Mac) |
Focus on Specific Profile |
Up/Down/Left/Right Arrow Keys |
Apply Profile to Current Actor |
Enter |
Enter |
Vector Grouping Tool |
Function |
Shortcut (Mac) |
Focus on Desired Group Name (Group Name Selection Pane) |
Up/Down Arrow Keys |
Focus on Desired Item (Style List Pane) |
Validate Multi-angle Setup |
Function |
Shortcut (Mac) |
Preview/Stop Bone Rotation |
Spacebar |
Spacebar |
Sprite Editor |
Function |
Shortcut (Mac) |
Preview/Stop Animated SWF |
Spacebar |
Spacebar |
Add Full Angle |
Ctrl + N |
Command + N |
Add Current Angle |
Ctrl + Shift + N |
Command + Shift + N |
Replace Full Angle |
Ctrl + R |
Command + R |
Replace Current Angle |
Ctrl + Shift + R |
Command + Shift + R |
Copy to All Angles |
Ctrl + O |
Command + O |
Copy to Current Angle |
Ctrl + Shift + O |
Command + Shift + O |
Delete Current Sprite |
Delete |
Delete |
Delete Full Angle |
Ctrl + Delete |
Command + Delete |
Delete Current Angle |
Ctrl + Shift + Delete |
Command + Shift + Delete |
Show/Hide Full Angle Setting Panel |
T |
T |
Mask Editor |
Function |
Shortcut (Mac) |
Undo |
Ctrl + Z |
Command + Z |
Redo |
Ctrl + Y |
Zoom in/out |
Mouse wheel |
Mouse Scroll |
Zoom In |
Zoom Out |
Zoom Fit |
Zoom Real Size |
Brush Size |
[ to decrease |
[ to decrease |
Switch Front/background Brush |
B |
B |
Color Range |
Mouse Click + Shift to increase |
Brush |
B |
B |
Eraser |
E |
E |
Blur |
R |
R |
Face Fitting Related Steps |
Function |
Shortcut (Mac) |
Undo |
Ctrl + Z |
Command + Z |
Redo |
Ctrl + Y |
Zoom In |
Zoom Out |
Zoom Fit |
Zoom Real Size |
Preview/Stop |
Spacebar |
Spacebar |
Eye Settings |
Function |
Shortcut (Mac) |
Preview/Stop |
Spacebar |
Spacebar |
Left Eye |
Right Eye |
Check Eye |
Miscellanea |
Function |
Shortcut (Mac) |
Fix SWF Broken Issues |
Ctrl + L |
Command + L |
Import Model |
Ctrl + M |
