Applying Cloth Template
In Character Creator, you can dress your character using built-in templates and customize parameters for shaping, texturing, and material setting to transform the clothes into various styles.
Clothing Character with Templates
Launch Character Creator and apply the base character from the asset library.
Switch the Content Manager to Cloth Template.
Open the desired library under the Cloth Template (in this case, the Pants).
Note:There are three ways to switch to the desired library:
- Quick Selection Panel: If you need to switch between different
categories or libraries, then you need to use the
Quick Selection Panel.
- Tree View: If you only want to switch between different libraries
under same categories, then use the tree-view in the Content Manager.
- Path Field: In addition to the
tree-view, you
can also change to different
libraries under an identical category by click the arrow button in the Path Field.
Apply either one of the templates (in this case, the Jean_E) by double-clicking
on it.
The clothing will be applied to the character.
Repeat the same steps until the character has a desired outfit.
Note:The clothing will automatically adapt to the body shape even after morphing the body parts.
Refer to the sections below to fix persistent mesh penetration:
Getting Content Pack
For more clothing options, visit the
official website
to purchase additional content packs.
