Theory of SSS
Basically, the directly reflected light from the object surfaces is defined via the Roughness and Metallic textures. This mechanism is sufficient for rendering most of objects.
The SSS (sub-surface scattering) effect, however, is a mechanism of light transport. The light pass through the surface of a translucent object, interact with and inside of the material at irregular angles, and then exits the surface and scatters. Please note that the SSS including the SSS Light and SSS Transmission LIghts.
Therefore, the human skin's material should not only directly reflect light
but also the blend sub-suface scattering.
