New Contents for SSS Shader
In Character Creator V3.3 or later version, there are materials templates with SSS Shader (Sub-surface Scattering shader) prepared for you to quickly apply SSS effect to desired objects (Hair, Prop, Accessory, Cloth, G1, Game Base in Character Creator, and Humanoid Characters used in iClone).
You can find them in the Material > SSS library.
The semi-transparent effects on object can be seen as the following illustrations.
Prop applied with PBR shader |
Props applied with SSS shader |
