Blend Map
The Blend Map parameters are used to adjust the Brightness and Saturation of the Base Color texture in the Texture Settings section. These
adjustments leave the original texture untouched while adjusting the surface tone.
- Base Color Blend Map Brightness: This value adjusts the brightness of the base color texture.
Base Color Blend Map Brightness = 0.000 (default)
Base Color Blend Map Brightness = 0.100
- Base Color Blend Map Saturation: You can use this slider to adjust the color saturation of the base color texture.
Base Color Blend Map Saturation = 0.000 (Default)
Base Color Blend Map Saturation = 0.500
