Using Normal Templates
There are four sub-libraries in the Normal Effects library, and they are Facial Wrinkle, Body, Noise and Detail Skin.
Facial Wrinkle
In the Facial Wrinkle library, you can apply the templates to create wrinkles on the entire face or certain regions on the face.
  • Facial Wrinkle:
    Skin without normal templates applied.
    After the normal templates are applied.
  • Facial Part:
    You can apply the templates in this sub-library to apply wrinkles on certain region of the face.
    Only the cheeks wrinkles are applied.
  • SkinGen Pack: You must purchase and install SkinGen Plugin to get this pack.
Body
Apply the templates in the library to enhance the line on the body.
  • SkinGen Pack: You must purchase and install the SkinGen Plugin to get this wrinkles pack.
  • Basic Template for Body:
    Body skin without normal templates applied
    Normal template is applied
Noise
Apply the templates in the library to create coarseness on the body.
Body skin without noise templates applied.
Noise normal template is applied.
Levels
The detail bumpiness can be created by the template in this library.
  • Face:
    After the detail skin templates are applied.
  • Body:
    You can use the templates in this sub-library to apply detailed lines onto the body.
    Detail Skin template is applied.
  • SkinGen Pack: You must purchase and install the SkinGen Plugin to get this pack.
