Generating Target for Creating Morphing Slider
Exporting the current character into an avatar file in OBJ format has special implications. You can adjust the file in any other 3D-modeling tool and load it back for creating custom morphing sliders.
Prepare a character (optionally morph the character).
Execute the File >> Export >> OBJ >> Nude Character in Bind-Pose command.
Adjust the settings according to the axis coordinate system of your
target 3D-modeling tool.
Note:Choosing Full Body radio button to export the character including body, eyeballs and teeth; while the Body radio button to export only the body without eyeballs and teeth.
- Click the Export button to export one folder storing all
material textures and three files in *.mtl, *.obj, and *.ObjKey format. The last one includes the
DRM data for the *.obj file. DO KEEP these two files because you will need it when you load
the modified OBJ Avatar back to Character Creator as target morphing character.
Modify the OBJ file with an external 3D-modeling tool.
With the mtl file and texture folder, you can re-build the look of the entire character.
Note:- Feel free to use any kind of 3D-modeling tools, such as 3ds Max, Maya or ZBrush.
- DO NOT change the total number and structure of the vertex in the OBJ avatar by means of any features such as sub-division, slice, add/delete vertices, etc.
Save the OBJ avatar and use it as the target morphing character in
Character Creator.
The morphing result
Applying clothes and motions
Note:Please refer to the Creating Morphing Slider for Changing Character Appearance section for more information.
