Sending Character to iClone
If you simply want to merely send the character to iClone without saving it as a file, then follow the steps below. This method helps you updating the currently used character in iClone without saving it as an character repetitively in Character Creator.
Create a character.
Execute the File >> Export >> Send Character to iClone command.
Alternatively, you can click the Send Character to iClone button on the Project toolbar.
Note:The resolution of the texture images burned on the character will be determined by the settings in the Appearance tab of the Modify panel.
The character will be applied into iClone current project (if iClone is not launched, then
it will be launched with a new project with the exported character).
Modify the character in Character Creator.
Send the character to iClone again by clicking the Send to iClone button.
If the character in iClone is already picked, then it will be replaced.
However, if it is not picked, then a new character will be applied into the current iClone project.
