Using First Frame in Bind Pose Feature
Exporting a character with motion in FBX format is an uni-directional workflow. Therefore, the FBX file can be edited in an external 3D application but can not be transferred back into Character Creator for body shape or outfit editing. Deactivate the First Frame in Bind Pose can facilitate this uni-directional workflow, for example, publishing your character to Sketchfab.
  1. Prepare a CC1 Base, CC3 Base or CC3 Base+ character.
  2. Execute File > Export > Fbx > Clothed Character command.
  3. In the following panel, set the export type to Mesh and Motion, choose the Custom option, and click the Open File button.
  4. The Custom option lets you include an .iMotion or .iMotionPlus animation track along with the FBX file.
  5. When you export the character with the settings above, a warning message should appear. Skip over this pop-up by pressing the OK button.
  6. Edit the motion in another 3D software.
    Before editing in (Maya)
    After editing
If First Frame in Bind Pose is activated, then you are free to create Character Creator compatible assets in 3rd party 3D applications.
  3. In the following panel, set the export type to Mesh and Motion and choose the Custom option, click the Open File button.
  5. Activate First Frame pose type > Start with > BindPose.
    A T-pose for CC1 Base, CC3 Base characters and an A-pose for CC3 Base+ will be inserted one frame ahead of the time-line motion.
    Bind-pose (T-poser) for CC1 Base and CC3 Base characters
    Bind-pose (A-poser) for CC3 Base+ characters
    1. Activate First Frame pose type > Start with > BindPose.
      Please note that if First Frame Pose Type is disabled, it may be due to one of the following reasons:
      • This setting is mutually exclusive with T-Pose. Please select another option instead (Calibration, Current Pose, Current Animation, or Custom).
      • The character has not yet been Characterized.
    2. Dress the character without changing the pose at the T-pose or A-pose frame of the character with an external 3D application.
      Bind-pose (T-poser) for CC1 Base and CC3 Base characters in 3D tools
      Bind-pose (A-poser) for CC3 Base+ characters in 3D tools
    3. The adjusted animation can be brought back into Character Creator using the FBX format for further editing without any issues due to the inclusion of a pristine T-pose or A-Pose frame.
      The T-pose for CC1 Base or CC3 Base characters is retained
      Other poses can be applied without a problem.
      The T-pose for CC3 Base+ characters is retained after being imported back to Character Creator
  6. Dress the character without changing the pose at the T-pose or A-pose frame of the character with an external 3D application.
  7. The adjusted animation can be brought back into Character Creator using the FBX format for further editing without any issues due to the inclusion of a pristine T-pose or A-Pose frame.
