The Relationships between Regions and Expression Sliders
When Check with Expressions is enabled, expression
morphs for the selected region of the face will automatically activate
with inflated values.
You can open the Edit Facial panel and select the "Currently Used" item in the
Modify tab to view the sliders that are engaged.
The relationships between the regions and expression sliders are as
follows:
- Wrinkle Set 1:
- Wrinkle Set 2:
- Wrinkle Set 3:
