Creating Morphing Sliders for Default Characters
  1. Prepare a target character in OBJ or iAvatar format.
  2. Launch Character Creator and load a CC3+ or CC5 character to the scene (In this case a CC3+ base character).
  3. Retrieve the default appearance of the character.
  4. Perform Create > Morph Slider Editor to open the panel.
  5. Name the slider and add a path.
  6. Set Morph Value > Minimum to 0 and Maximum to 100, so that when the custom slider is set to maximum the character retains its original look.
  7. To create a thumbnail, click the button and load an existing image.
  8. In the Source Morph radio button group, choosing either the Default Morph or the Current Morph option gives the same results.
  9. In the Target Morph radio button group, choose the File one and load the character prepared in step 1 by clicking the button.
  10. Click the OK button to add your custom morph slider into the designated node and path.
  11. Drag the slider and you will see the default character is gradually transformed to the target character.
    Value = 50
    Value = 100
  12. You can still use the default sliders to further adjust the new character.
