Setting Facial Expressions by Face Muscles
The first mode in the Edit Facial panel is the Muscles, where you can adjust the facial expressions by dragging on the muscle regions.
  1. Create a project and apply a character.
  2. Click the Edit Facial button under the Motion Pose tab in the Modify panel.
  3. In the Edit Facial panel, switch to the Muscles mode.
  4. Select the areas on the dummy face to pick the desired muscle.
  5. Drag in the reaction area to set the facial features:
    The character will instantly react to the adjustments.
  6. The two buttons at the top right corner of the dummy pane can be used to rotate the head.
  7. If you activate the Symmetrical Selection checkbox to adjust bilateral muscles simultaneously.
