Using Cloth Conforming Feature
When you increase the size of the inner meshes of a skin poking through out of the outer ones, you can simply use this method to hide the penetrating part by following steps:
  1. Create a new project and dress the character.
  2. Increase the size of the entire body or specific body part. Sometimes the partial mesh of the skin maybe poke through the cloth as the illustration shows.
    You can turn the upper layer of the mesh into wireframe mode to get a better view of the poke-through.
  3. Select the cloth at the topmost layer (in this case, the yellow top dress).
  4. Execute the Modify >> Conform command to launch the Conform Clothing panel.
    Alternatively, click the Conform Clothing button on the Modify Tools toolbar.
  5. Setting the parameters in the panel and click the Calculate Collision button to lift the cloth meshes off the ones under.
    The meshes poking through the cloth will be covered by the enlarged cloth meshes.
