Character Creator provides Decal feature in the Texture tab of Modify panel. You may then use this feature to add tattoo, scars or any special patterns or prints onto the surface of the skin. The advantage is that you are able to scale, rotate or move the decal to any location on the body without the need to edit the original texture images of the body.
Note: |
Please note that you must have purchased Essential Morphs & Skin content pack in order to have the input channel for loading custom images. |
Note: |
You are able to layer up to three images onto the original face texture. |
Note: |
If you load a PNG image into the Diffuse channel, the alpha data of the image will automatically masks out the un-necessary part of the image without the need of load a grayscale image to the Mask channel. |
