Using Body Skin Templates
In Character Creator, several well-designed body skin texture templates are prepared for certain purposes. You can freely apply them to have the character with different body skin complexion.
Note:
For consistency, when you apply the body skin template, the entire skin textures of the character, including the head and body, will be changed simultaneously.
Applying Body Skin Templates
  1. Launch Character Creator, by default, there will be a nude character.
  2. Switch the Content Manager to Skin Template >> Normal library.
    Note:
    There are three method to switch to desired library:
    • Quick Selection Panel: If you need to switch between different categories or libraries, then you need to use the Quick Selection Panel.
    • Tree View: If you only want to switch between different libraries under same categories, then use the Tree View in the Content Manager.
    • Path Field: In addition to the Tree View, you may also change to different libraries under an identical category by clicking on the arrow button in the Path Field.
  3. Apply either one of the template (in this case, the Old Lady) by double-clicking on the template. The character's skin tone and texture will be retouched while the facial features are left unchanged.
Getting Content Pack
If you want to have more options for the face appearances of the character, please go to the official website for purchasing the content pack.
