Attaching Accessories to a Character
If you wish to attach the accessory to any body part, then you may use the Attach feature to do so.
Attach to Body Parts
  1. In the Character Composer, make sure the accessory is selected and then click the Attach button found on the tool bar.
  2. Click on the target body part or facial feature, to attach the accessory.
    The parent node of this prop is now changed to the body part you assigned.
  3. Move, rotate or scale the accessory to the appropriate location or size.
  4. Click the Back to Stage button to leave the composer mode and update the character.
  5. When the character is in motion, the prop will move along with the character.
