Using the Opacity for Fade In and Fade Out
The Opacity setting not only decides the transparency of a character, prop or image layer, but it can also create fade in and fade out effects. You can create fade in and fade out effects in any project by altering the opacity values of the image layer.
  1. Select a prop. (If you want to select an image layer, then select it from the Scene Manager)
  2. By default, the Opacity of a prop is 100. Change it to 0 (zero).
  3. Go to another time frame where you want the selected prop to fade in. Change the Opacity value of the item to 100. Play back to see the prop gradually appear.
    Opacity = 50
    Opacity = 100
