When applying motions one after the other, you will often come across a problem where the last frame of the first clip doesn't match the first frame of the second clip. The character may be in two completely different poses, and this can cause a problem when transitioning from one clip to another. In order to blend the poses, you need to use the Blending feature on the Timeline.
Each clip contains a transition area at the beginning. Find out how to use this area to blend two clips together below.
Note: |
Still interval pose (without blending) |
Snapping to the second pose with a sudden change |
Note: |
The blending area can overlap the previous clip if you want the blending effect to happen earlier. |
When a character has two motions that are in different directions, the hopping issue will be even more obvious because both the directions and the motions suddenly change when the play back runs to the start frame of the latter clip. To solve the hopping issue, simply add transition effects between two motion clip and the hopping issue will be alleviated tremendously.
The first running motion is at 315 degrees. |
The second running motion is at 0 degrees. |
