Transition Curves in Tracks
In CrazyTalk Animator, you are able to set keys or add clips into different tracks. Interpolations can be customized between different curves so that the transition speeds between two adjacent keys, imitate the physical characteristics of how the object would move in the real world.
Set the Transition Curve
  1. In the target track of the timeline, set two keys (take the Transform track as an example).
  2. Right-click on the Later one. Select an item from the Transition Curve entry in the menu.
    The transition curve will then be generated between these two keys only.
Transition Curves
Linear - Constant Speed
Ease In & Out - Slow, Fast, Slow
Ease In - Acceleration
Ease Out & In - Fast, Slow, Fast
Ease Out - Deceleration
Step
Dramatizing the Transition Curves
If you need more dramatic transition results, then you may use the Custom feature provided in the pop-up menu to adjust the steep of the transition curves.
  1. Right-click on the Later key. Select Transition Curve >> Custom.
  2. Select a curve type from the Curve Option drop-down list.
  3. Drag the slider to increase or decrease the variation of the curve. Note: When you decrease to the left-most side, the curve will be very similar to the linear curve.
    Less dramatic
    General Ease In
    More dramatic
    Dramatized transition
