It is highly recommended that you set your pivots according to our template, and name them properly. Please refer to the downloaded Actor Naming List_Sprite_Pivot_Pose.xls to find the correct names for the pivots.
Note: |
If you delete a pivot by accident, you can find the pivot in Elements > Default Content > Pivot. Drag the pivot you want back to the corresponding track, correctly relocate it in the stage and name it accordingly. |
For best accurate pivot location and smooth joint motion, please follow the steps below:
Note: |
