Front Face Control Point Placement Guide
Refine Face uses control points and handles to create Bézier curves that outline the face and guide head mesh generation. Accurate anchor point placement is crucial, as it defines the vertices used for mesh generation and improves facial proportions and topology matching to the reference photo.
Special Control Point Guidance
Hovering over certain control points displays additional visual instructions to assist with correct placement:
- Eyebrow Points (4 points) -
Follow the lower contour of the eyebrow to define the brow ridge accurately.
- Chin Points (2 points) -
Place slightly below lip level to maintain correct lower-face proportion and jaw alignment.
The Table for Skull Control point Placement
Parts |
Reference Image |
Name |
Description |
Skull |
Right nadir of the skull cap. |
Right-side point on the head outline, aligned above the temple area. |
Skull |
Right median of the skull cap. |
Upper-right point on the head outline, between the side and top of the skull. |
Skull |
Apex of the skull cap. |
At the very top of the skull mesh. |
Skull |
Left median of the skull cap. |
Upper-left point on the head outline, between the side and the top of the skull. |
Skull |
Left nadir of the skull cap. |
Left-side point on the head outline, aligned above the temple area. |
Chin |
Left apex of the lower jaw. |
Highest point of the left jaw, likely to parallel with the mouth. |
Chin |
Left median of the lower jaw. |
Between the chin center and left jawline that defines the mid-jaw contour. |
Chin |
Nadir of the lower jaw. |
At the lowest point of the Chin. |
Chin |
Right median of the lower jaw. |
Between the chin center and right jawline that defines the mid-jaw contour. |
Chin |
Right apex of the lower jaw. |
Highest point of the right jaw, likely to parallel with the mouth. |
The Table for Eyes Control point Placement
Parts |
Reference Image |
Name |
Description |
Right Brow |
End point of the right brow ridge. |
The most raised point at the end of the right brow bone. Usually located below the brow ridge. |
Right Brow |
Starting point of the right brow ridge. |
The most raised point at the inner end of the right brow bone, near the center of the forehead. Usually located below the brow ridge. |
Left Brow |
Starting point of the left brow ridge. |
The most raised point at the inner end of the left brow bone, near the center of the forehead. Usually located below the brow ridge. |
Left Brow |
End point of the left brow ridge. |
The most raised point at the end of the left brow bone. Usually located below the brow ridge. |
Right Eye |
Outer-corner of the right eyelid. |
Right Eye |
Apex of the right eyelid. |
The highest point of the right eyelid. |
Right Eye |
Inner-corner of the right eyelid. |
Right Eye |
Nadir of the right eyelid. |
The lowest point of the right eyelid. |
Left Eye |
Inner-corner of the left eyelid. |
Left Eye |
Apex of the left eyelid. |
The highest point of the left eyelid. |
Left Eye |
Outer-corner of the left eyelid. |
Left Eye |
Nadir of the left eyelid. |
The lowest point of the left eyelid. |
Right Eye Socket |
Outer-corner of the right eye socket. |
Outer-corner of the right eye socket. It extends radially outward from the respective eye points as shown in the indication image with the dotted line. |
Right Eye Socket |
Apex of the right eye socket. |
Topmost point of the right eye socket. It extends radially outward from the respective eye points as shown in the indication image with the dotted line. |
Right Eye Socket |
Inner-corner of the right eye socket. |
Inner-corner of the right eye socket. It extends radially outward from the respective eye points as shown in the indication image with the dotted line. |
Left Eye Socket |
Inner-corner of the left eye socket. |
Inner-corner of the left eye socket. It extends radially outward from the respective eye points as shown in the indication image with the dotted line. |
Left Eye Socket |
Apex of the left eye socket. |
Topmost point of the left eye socket. It extends radially outward from the respective eye points. |
Left Eye Socket |
Outer-corner of the left eye socket. |
Outer-corner of the left eye socket. It extends radially outward from the respective eye points as shown in the indication image with the dotted line. |
Right Double Eyelid |
Outer-corner of the right eyelid fold. |
Outer-corner of the right eyelid fold.It extends radially outward from the respective eye points as shown in the indication image with the dotted line. |
Apex of the right eyelid fold. |
Topmost point of the right eyelid fold. It extends radially outward from the respective eye points. |
Inner-corner of the right eyelid fold. |
Inner-corner of the right eyelid fold.It extends radially outward from the respective eye points as shown in the indication image with the dotted line. |
Left Double Eyelid |
Inner-corner of the left eye fold. |
Inner-corner of the left eyelid fold.It extends radially outward from the respective eye points as shown in the indication image with the dotted line. |
Apex of the left eyelid fold. |
Topmost point of the left eyelid fold. It extends radially outward from the respective eye points as shown in the indication image with the dotted line. |
Out-corner of the left eye fold. |
Outer-corner of the left eyelid fold. It extends radially outward from the respective eye points as shown in the indication image with the dotted line. |
The Table for Nose Control point Placement
Parts |
Reference Image |
Name |
Description |
Nasolabial |
Apex of the right nasolabial fold. |
Upper end of the right nasolabial fold. |
Nasolabial |
Nadir of the right nasolabial fold. |
Lower end of the right nasolabial fold. |
Nasolabial |
Apex of the left nasolabial fold. |
Upper end of the left nasolabial fold. |
Nasolabial |
Nadir of the left nasolabial fold. |
Lower end of the left nasolabial fold. |
Nasal midline |
Apex of the nose bridge. |
Topmost point of the nose bridge. |
Nasal midline |
Nadir of the nose bridge. |
Lowest point of the nose bridge, right above the nose bulb. |
Nasal midline |
Apex of the nose bulb. |
Highest point of the nose bulb. |
Nasal midline |
Nadir of the nose bulb. |
Lowest point of the nose bulb. |
Nostril |
Outer-corner of the right nostril. |
Nostril |
Inner-corner of the right nostril. |
Inner corner of the right nostril. |
Nostril |
Inner-corner of the left nostril. |
Nostril |
Outer-corner of left nostril. |
Outer-corner of the left nostril. |
Right Nose Line |
Right-side of the nose bridge. |
Right Nose Line |
Apex of the right nose wing. |
Highest point of the right nose wing. |
Right Nose Line |
Median of the right nose wing. |
The middle point of the right nose wing. |
Right Nose Line |
Nadir of the right nose wing. |
Lowest point of the right nose wing. |
Right Nose Line |
Right nadir of the nose bulb. |
Right Lowest point of the nose bulb. |
Left Nose Line |
Left-side of the nose bridge. |
Left Nose Line |
Apex of the left nose wing. |
Highest point of the left nose wing. |
Left Nose Line |
Median of the left nose wing. |
The middle point of the left nose wing. |
Left Nose Line |
Nadir of the left nose wing. |
Left Lowest point of the nose bulb. |
Left Nose Line |
Left nadir of the nose bulb. |
Lowest point of the left nose wing. |
The Table for Lips Control point Placement
Parts |
Reference Image |
Name |
Description |
Lip |
Right corner of the lips. |
Right corner of the lips |
Lip |
Philtrum dip of the lips. |
Lip |
Left corner of the lips. |
Lip |
Nadir of the lips. |
Lowest point of the lips |
Lip liner |
Right corner of the lip line. |
Right corner of the lip line |
Lip liner |
Center of the lip line. |
Center of the lip line |
Lip liner |
Left corner of the lip line. |
Left corner of the lip line |
