Modify Front Image with AI Image Generator
Defective images can be fixed with the AI Image Generator. With simple selection, any defective image with a face can be regenerated to match the standard of the source image, in order to optimize the generation result.
Modifying Images
Multiple defects can all be fixed in one generation:
  1. Load the Image.
  2. Select the desired modification(s), in this case check Enhance Image, Remove Hair and Remove Beard.
  3. Select the desired resolution for the image. In this case, Choose 4K.
  4. Press Generate Image and wait.
  5. The following are a comparison between the original image and the modified image.
    Not Facing Front
    Have Facial Expression
    Have Hair
    Have Beard
    Enhance Image
    Remove Hair
    Remove Beard
The following are examples of each type of image modifications:
Optimizing Front Images
Uneven Lighting
Optimized
Exaggerated Expression
Optimized
Angle
Optimized
Wearing Glasses
Optimized
Head Cropping
Optimized
Black & White
Optimized
Optional Modifications
Have Hair
Remove Hair
Have Eyelash
Remove Eyelash
Have Beard
Remove Beard
Have Eyebrow
Remove Eyebrow
Have Makeup
Remove Makeup
