Modify and Enhance Image with AI Image Generator
Defective images can be fixed with the AI Image Generator. With simple selection, any defective image with a face can be regenerated to match the standard of the source image, in order to optimize the generation result.
Image generation costs are fixed at 15 points for 2K and 30 points for 4K, regardless of how many modifications are selected.
Modifying Images
Multiple defects can all be fixed in one generation:
- Load the Image.
- Select the desired modification(s), in this case check Enhance Image, Remove Hair and Remove Beard.
- Select the desired resolution for the image. In this case, Choose 4K.
- Press Generate Image and wait.
- The following are a comparison between the original image and the modified image.
Not Facing Front
Have Facial Expression
Have Hair
Have BeardEnhance Image
Remove Hair
Remove Beard
The following are examples of each type of image modifications:
Optimizing Front Images
Uneven Lighting |
Optimized |
Exaggerated Expression |
Optimized |
Angle |
Optimized |
Wearing Glasses |
Optimized |
Head Cropping |
Optimized |
Black & White |
Optimized |
Optional Modifications
Have Hair |
Remove Hair |
Have Eyelash |
Remove Eyelash |
Have Beard |
Remove Beard |
Have Eyebrow |
Remove Eyebrow |
Have Makeup |
Remove Makeup |
