Image Plane Settings
A
Side / Custom
Switch between the Side image workflow and the Custom image workflow.
B
Image Tool
Load, paste, or remove images from the image plane.
  1. Load: Load an image to the image plane.
  2. Paste: Paste an image from the clipboard.
  3. Delete: Remove the current image.
C
Image Display
Displays the loaded image. Images can be loaded by:
  • Double-clicking the display area.
  • Dragging and dropping an image.
  • Clicking the Load button.
  • Pasting an image from the clipboard.
D
De-Light
Enable De-Light to reduce lighting and shadow information in the image. Adjust the slider to set the De-lighting strength.
E
Flip
Flip the stencil image horizontally or vertically.
F
Adjust Color
Open the Adjust Color panel to modify the color properties.
G
Pin Image Plane
Pins the image plane to the viewport so it follows camera zooming and panning.
Show / Hide Image
Toggle the visibility of the image plane.
Opacity
Adjust the transparency of the image.
Rotation
Adjust the image's rotation angle.
Scale
Adjust the size of the image.
Reset Image Plane
Reset the image plane's rotation, position, and scale to their default values.
